CUCM 6 Mobility services will not start
Apr 17th, 2008
Hello All,
I am having a problem on my CUCM 6 DEMO edition where the Cisco Extension MObility and Cisco Unified Mobile Voice Access Services will not start. They both show as Not running in the Unified Serviceability. Any help would be appreciated.
Jaime Valencia Thu, 04/17/2008 - 18:21
have you enabled them at the control center before trying to start them?
if this helps, please rate
scottm65 Fri, 04/18/2008 - 07:19
Thank you for the reply.
I have indeed enabled/activated the services in the Service Activation under "Cisco Unified Servcieability". Then when I go to Control Center - Feature Services it shows the status "Not Running". When I try to start the services it still says Not Running. It appears to be just those 2 services. All others that are activated are running correctly.
I have not been able to find anything on this and have tried a couple tools.
