04-17-2008 05:26 PM - edited 03-13-2019 05:10 PM
Could anyone help me reset the config password of 7960? I bought the unit from Ebay, I got the phone reset to factory default already and I don't know the default password. Anyone? Thanks.
Solved! Go to Solution.
04-18-2008 09:53 AM
I've found this doc from a service provider offering a VoIP connection via SIP.
http://www.hablavoip.net/download/manuals/Guida%20Cisco%20CP7960_rev1-0.pdf
It is in italian, but you can easily see at top of page 5 it says the default password is "cisco".
Alberto
04-18-2008 05:32 AM
what do you mean for the 7960 config password ?
which settings are you trying to change ?
To unlock network settings you may use the **# code.
alberto
04-18-2008 09:39 AM
its the unlock config password on the phone menu. thanks.
04-18-2008 09:53 AM
Alberto
04-18-2008 10:14 AM
thank you. it works. i just have to keep pressing for the right letter.
04-21-2008 09:06 PM
Hi Which buttons did u press. is it **# or ? pls let me know.
regards
Esa
