Cisco 4506
Apr 17th, 2008
Need help configuring port for full 1000. speed 1000 but duplex is set at auto. How do I change it?
sundar.palaniappan Thu, 04/17/2008 - 19:29
I believe only full duplex is supported when speed is set to 1000 mbps. Hence, it should already be doing auto-full duplex with 1000 speed. The following CCO link seems to suggest the same.
From CCO
""Setting the Interface Duplex Mode
Note When the interface is set to 1000 Mbps, you cannot change the duplex mode from full duplex to half duplex.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/25sg/configuration/guide/sw_int.html
Sundar
