DHCP Manual binding issue
Apr 17th, 2008
Hi everyone,
I created a manual binding for my DHCP service but it never worked. It always receives the dynamic PI from its parent pool.
ip dhcp pool parentPool
network 10.1.1.0 255.255.255.0
default-router 10.1.1.254
dns-server 139.130.4.4 61.3.133.192
option 42 ip 128.250.36.2 128.250.36.3
ip dhcp pool manualPool
host 10.1.1.250 255.255.255.0
hardware-address 0010.4918.1225 ieee802
client-name myVoiceSwitch
I even tried to stop and start DHCP service again. Is there anything I missed?
Best regards,
Triet
Syed Iftekhar Ahmed Fri, 04/18/2008 - 00:02
if the DHCP client is a Microsoft client, replace
the "hardware-address 0010.4918.1225 ieee802"
command with
"client-identifier 0100.1049.1812.25 " command where the first 01 represents
a media type of Ethernet.
Syed
trietgiang Fri, 04/18/2008 - 02:45
How do you define a Microsoft client? This is a ShoreGear switch (ShoreTel VoIP switch), I guess it is not Microsoft.
However I tried this option, doesn't work either.
Could you please advise another option?
Thank you
Triet
trietgiang Sat, 04/19/2008 - 04:59
Yes I have, with either "ieee802" and "ethernet" option.
I even reloaded the router just to be sure.
carl_j_meza Sat, 04/19/2008 - 05:10
Here is a static reservation config that works--just scrambled the names and numbers.
ip dhcp pool local-network-pool
import all
network 10.20.30.128 255.255.255.248
default-router 10.20.30.129
dns-server 10.20.20.10
domain-name not-real-domain.org
netbios-name-server 10.20.20.10
ip dhcp pool static-ip-for-device
host 10.20.30.130 255.255.255.248
hardware-address 0024.0d55.7c53
trietgiang Sun, 04/20/2008 - 16:15
I found the cause of the problem. In the config, there was an: ip dhcp excluded-address 10.1.1.150 10.1.1.255. And the address I tried to set is 10.1.1.250.
I always thought that those reserved IPs are for manual binding. Actually the manual binding is part of the DHCP server and it takes the excluded-address range into account as well.
Thank you very much for all your help. I really appreciate it.
Triet
