ASA 5510 VPN can't connect to LAN and SERVERS
Apr 17th, 2008
Hello guys, I'm new to Cisco and I need your help. I have configured the ASA 5510 to accept vpn connections but I can't connect to the lan and can't ping to servers. We are using a 3560G switch as core switch. Please see my config if I missed something along the way. Thank you guys.
acomiskey Fri, 04/18/2008 - 05:42
  • Green, 3000 points or more
Have you tried it without a vpn-filter.
vpn-filter value none
helios999 Fri, 04/18/2008 - 16:42
Hi, thanks for the reply. I have not tried using that syntax. Correct me if I'm wrong but this vpn-filter syntax will allow you to access a certain network allowed in the access list?
I will try using value none.
