Backup ACS
Jagdeep Gambhir Fri, 04/18/2008 - 05:20
No , you will not loose your database but it is highly recommended to take a backup before you start with the upgrade.
Upgrade path will be 4.0--->4.1.1---->4.1.4
Do rate helpful posts
Jagdeep Gambhir Thu, 05/22/2008 - 10:38
No, ACS se can't store logs for other acs but acs can send logs to the system running remote agent. Remote logging.
Jagdeep Gambhir Tue, 05/27/2008 - 05:53
Yes, that is possible. You need to edit csagent.ini file of remote agent.
On the system running remote agent , open ini file and add one more configproviderhost.
C:\Program Files\Cisco\CiscoSecure ACS Agent.
jthienhaus Wed, 05/28/2008 - 08:04
Hi There!
I've got a Question regarding to the Backup of an ACS Service Engine ver A couple of days ago I've upgraded the ACS Service Engine from ver 3.2.2 to ver following the upgrade path to finally have the 4.1 version installed. The upgrade to the ver 3.3.3 was succesfull, it conserved the database and continue to autenticate the users, BUT when I wanted to make a Backup of the ACS via FTP it shows this error message:
"1. Manual Backup Started"
"2. CSBackupRestore(OUT) export function exportSnmpConfig in DLL D:\Program Files\Cisco Secure ACS v3.3\Support\backupRestoreSupport.dll FAILED"
"3. Backup failed due to FTP error. The server name or address could not be resolved"
Prior to the upgrade I could make backup copies of the ACS configuration (in the ver 3.2.2), so the ftp is working.
Any Ideas??? I'll be very thankfull for any assistance. Thanks in advanced!
Jagdeep Gambhir Wed, 05/28/2008 - 08:21
please change the Directory in ACS backup setting to just " / " and see if this works.
yesterday I upgrades my appliance ACS 1113 of the version to the ( - -
And in the process, my database corrupted. I have lost users and groups with EAP-FAST authentication.
Now, I need CD to restore the backup database, and then to convert it at 4.1 version. But I don't have CD instalation of the 4.0. Could you give me?.
PD. What happened? You told me that it would not lose my database.
