Problem with lms 3.0 Dec update
Apr 18th, 2008
since I installed the lms Dec update on my LMS 3.0, I have a problem to save the configuration of some 3750 switch and some Cat 4000 (with CatOS) in RME.
Ciscoworks writes that the configuration backup went correctly, but in fact, when we opened the file saved, only a part of the configuration was saved.
Somebody knows this problem?
Thank you for your help.
For information, my LMS works on Solaris.
Sam
Joe Clarke Fri, 04/18/2008 - 08:00
I have not seen an issue with config file truncation. Where are you going to open the file?
s.fasel Sun, 04/20/2008 - 22:11
I'm going to the directory:
/var/adm/CSCOpx/files/rme/dcma/shadow/Switches_and_Hubs/PRIMARY
It's the same result when I look these configurations directly in RME -> Archive Management
