Jon Marshall Fri, 04/18/2008 - 02:02
If you clear all translations with
"clear ip nat translations *" then all exisiting connections with nat translations will be torn down. You are not clearing the logs you are clearing the actual translations.
You can be more granular and specify a particular nat translation.
Jon
Jon Marshall Fri, 04/18/2008 - 02:45
Do a "sh ip nat translations"
and then
clear ip nat translation ? and you will see the options to specify a particular entry.
Jon
