CUCM 6.1 - BAT Export issue
Hi guys,
I doing some research on the BAT Export tool on our CUCM. But after I succesfully scheduled the job of Exporting all the Server/Call Routing/Media Resource items. I see in the job schedular that the job is Completed, but I can't see it in the list of Upload/Download Files.
Could it be that I'm running into a bug or something? Cause I can not see that I'm doing something wrong :S
System version: 6.1.1.2000-3
Guide used: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/6_0_1/t13cnftl.html
Kind regards,
Paul van den IJssel
Digacom
Eric Krieger Fri, 04/18/2008 - 04:50
Hi Paul,
I use the same version, no problems here.
I selected all items, entered a name and clicked on submit.
After a while, selected the according completed job id containing the logfiles of all exported items which were present in the created *.tar file under Upload/Download files. No erros/failures mentioned. Does your job contains failures?
Try to export some of the items, and see if the behaviour changes.
Eric
