CSSC 5.0
Apr 18th, 2008
hi,
simple question (hopefully with a simple answer)
when logging out of a windows xp laptop with CSSC 5.0.2 latest version running it seems to take some time to save the settings on windows when the close down / logout dialog box appears.
why could this be ? is there some tweaks.settings on timers i could play with on the setup (sccmanagement tool)
there is little to no disc activity for a while, then after about a 1 min the laptop is logged out and the windows login box appears correctly again.
cheers
Megz
Anonymous (not verified) Thu, 04/24/2008 - 06:29
you can refer to this bug for more details:CSCsl32404
meggerman Thu, 04/24/2008 - 07:25
rrjoas45 your reply is much appreiciated !
i shall look at this bug fix info
cheers
Megz
