04-18-2008 03:58 AM - edited 07-03-2021 03:44 PM
Hi, is it possible to combine(connect) autonomous AP in WGB mode with LAP in HREAP mode?
David
04-18-2008 04:54 AM
I don't see why that wouldn't work for you... The WGB as long as it has connectivity to an ap should be able to bridge traffic back to the LAN. If you are doing local switching, then it's as if you have an automous ap. Are you having problems connecting the WGB to an hreap ap?
04-22-2008 06:06 AM
I read in some sources that this does not work together so I just wanted to be sure before implementation. Thanks.
04-22-2008 08:06 AM
This may prove to be helpful.
04-18-2008 06:48 AM
