04-18-2008 04:06 AM
I've a Cisco VPN Client and a certificate on a smart card. I've imported this in Microsoft certificate store and the root CAS (say CA1 AND CA2). I want authenticate with a VPN Concentrator 3080 with software release 4.7.2 (the last). On the concentrator I've installed an identity certificate and the root CA (say CA2).
When i try to authenticate on Cisco VPN Client I've following errors:
"Failed to sign hash: B_EncryptInit() failed
Failed to RSA sign the hash for IKE phase 1 negotiation using my certificate
Failed to generate signature: Signature generation failed"
With another smart card I've the following errors:
"Certificate access error. Ensure SmartCard is not locked and is properly inserted.
Failed to RSA sign the hash for IKE phase 1 negotiation using my certificate.
Failed to generate signature: Signature generation failed "
Failed to build Signature payload
Do you know what is the reason?
Thank you
Best regards.
Massimiliano.
04-21-2008 04:23 AM
Does anyone have a solution to fix this problem?
Thank you.
Massimiliano.
01-07-2010 11:31 PM
I do not have an answer. Instead I have the same problem. Running Cisco VPN Client 5.0.05.0290 under Windows XP SP 3 with an Aladdin USB-eToken.
Any hints?
