Remote Access VPN with IPSec on a stick
Apr 18th, 2008
Hello there,
I'm trying to establish a connection into the internet over a Remote Access VPN Tunnel.
The VPN-Client connects to Cisco PIX via IPSec-Tunnel and then connects to any web-server on the internet over the IPSec Tunnel.
This Connection is never established.
Normal IPSec-Traffic is no problem. I think I've got a problem with NAT. Where do I have to configure the NAT Rule for the VPN-Clients - on the "INSIDE" iface???
Other configurations like ACLs or "same-security-traffic permit intra-interface" are already done.
Please help
See ya
Overall Rating: 5 (1 ratings)
acomiskey Fri, 04/18/2008 - 05:32
global (outside) 1 interface
nat (outside) 1
Make sure not to split tunnel, tunnel all traffic.
braulio.santos Sun, 09/14/2008 - 23:09
type route print in ur host and verify if the network or host than u need to gain acces is encrypted and maybe is split tunnel configuration
