aaa authorization ACA4.1
Apr 18th, 2008
i configure aaa on my switch and cannog get telnet loggin. in the PAsst Athem ACS Server: Authentication is OK, but FailItem Unknown NAS
Thanks for any Help
-----------------------------------------aaa new-model
aaa authentication login default group radius local
aaa authentication login CONSOLE local
aaa authentication enable default group tacacs+ enable
aaa authentication dot1x default group radius
aaa authorization exec default group tacacs+
aaa authorization exec CON none
aaa authorization network default group radius
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
Switch output:
Username: aessome-d
% Authorization failed.
Connection closed by foreign host.
Jagdeep Gambhir Fri, 04/18/2008 - 05:40
You want to use radius or tacacs ? Make sure you have priv 15 configured in acs,
Bring users/groups in at level 15
1. Go to user or group setup in ACS
2. Drop down to "TACACS+ Settings"
3. Place a check in "Shell (Exec)"
4. Place a check in "Privilege level" and enter "15" in the adjacent field
Do rate helpful posts
