OSPF Statistics command - clarification
Apr 18th, 2008
Dear All,
I have doubts on sh ip ospf statistics command output, I have executed this command in one of our router and got below output.
Area 0.0.0.0: SPF algorithm executed 191173 times
Summary OSPF SPF statistic
SPF calculation time
Delta T Intra D-Intra Summ D-Summ Ext D-Ext Total Reason
6d02h 4 4 0 0 48 0 56 R, N, SN, X
6d02h 4 0 4 0 48 0 56 R, N, X
6d02h 4 0 4 0 48 0 56 R, SN, X
5d01h 4 0 4 0 48 0 56 R, SN, X
5d01h 4 0 4 0 48 0 56 R, N, X
5d01h 16 0 0 0 96 0 120 R, N, SN, X
3d00h 8 0 0 0 48 4 60 R, N, SN, X
3d00h 8 0 0 0 48 0 56 R, N, SN, X
3d00h 4 0 4 0 48 0 56 R, N, X
While seeing the output delta, Intra, D-Intra, Sum, D-sum, Ext, D-Ext, Total and reson feilds. Not sure what is the meaning of these feilds and how would we know whether SPF calculation is happening frequently and which routes are getting flapped.
kindly share your inputs in this regard, appriciate any links to clarify these points.
Gopal
sundar.palaniappan Fri, 04/18/2008 - 07:04
  • Green, 3000 points or more
Gopal,
The link below explains all the different fields for you in the 'show ip ospf statistics' command. This should address most of your queries.
Command lookup tool is your best friend to interpret different values and parameters for all IOS commands. I highly recommend using this tool for any command related questions.
http://www.cisco.com/en/US/docs/ios/12_3t/ip_route/command/reference/ip2_s4gt.html#wp1167148
Sundar
