CCME Directory Services
Apr 18th, 2008
Ok, is there a way to remove an entry in the Local Directory without removing its DN? Basically I don't want the incoming lines to show up in the search function.
Thanks in advance.
Rob Huffman Fri, 04/18/2008 - 06:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Erik,
Have you tried the "clear' command?
1. enable
2. configure terminal
3. telephony-service
4. directory entry {entry-tag number name name | clear}
5. end
Hope this helps!
Rob
erikjustinlee Fri, 04/18/2008 - 06:46
That would only be if there is an entry for them right? Would it remove one of the entries that are automagicaly added?
Rob Huffman Fri, 04/18/2008 - 07:43
  • Hall of Fame,
    Founding Member
Hi Erik,
Yes, you are correct (this won't work :( Sorry, I wasn't thinking/reading at the same time.
I don't think this is possible.
Rob
