Unity Express voicemail reset
Apr 18th, 2008
Hi Guys,
I have never worked on unity express and need to reset a users voicemail password.I have logged into the service engine and need the command to change the password.I would like to do this via CLI rather than GUI.Any links to documentation will also be great.
Overall Rating: 5 (4 ratings)
Steellllllllll0 Fri, 04/18/2008 - 07:53
unity-e-vm(config)> user XXXX ?
create Add the user account
phonenumber Specify a number or extension for the use
None of the above commands work guys.These are the only options i have...
Brandon Buffin Fri, 04/18/2008 - 07:56
Type "exit" at this prompt and try the command again. You should not be in configuration mode.
Brandon
Kenneth Mohammed Fri, 04/18/2008 - 08:16
Thanks for that tidbit bbuffin...I have been racking my brain for the last longest on how to change the vm pw from the cli.
