VoIP setup
Apr 18th, 2008
Hi, I have two 3750's and two 3560's that I would like to use to create VoIP calls. Does anyone know if I can put a VoIP IOS on these switches? If you could let me know what IOS I need that would be very helpful. Basically, with these switches and a couple of IP phones I would like to test VoIP in a lab environment. If there is equipment I additionally need (server's, etc.) please let me know. I am just trying to do this as cheap as possible and as a channel partner we can get all the IOS software versions for free, so I was hoping to make use of that.
bwilmoth Thu, 04/24/2008 - 10:12
Switches support voice paskets to pas through but cannot process voice calls unless itis Layer 3 switch. You need tp have a router which supports voip supported ios. you can go for 2800,1800 routers with callmanager express.
