04-18-2008 09:06 AM
I have one site were i'm using regex matching to redirect certain requests to a different serverfarm. When i test the site it seems to work okay but when i role it into production this don't work correctly. I see alot of 404 messages and i can see in the server logs requests are bouncing around many times to the incorrect server.
We also use Akamai for our web acceleration and they stated that sticky cookies is what we should use for stickyness. The config is pretty straight forward but it seems to be an issue with load because when i test i don't see similiar results. Anyone have an issue like this or any other thoughts would be appreciated.
parameter-map type http HTTP-PARAM
case-insensitive
persistence-rebalance
length-exceed continue
ssl-proxy service http://www.microchipdirect.comSSL
key http://www.microchipdirect.com.key
cert http://www.microchipdirect.com.cer
chaingroup http://www.microchipdirect.com
serverfarm host http://www.microchipdirect.com/prog_sf
predictor leastconns
probe http
rserver chn-sv-iis-wfb1.dmz.mc-web.microchip.com
inservice
rserver tech.microchip.com
inservice
serverfarm host http://www.microchipdirect.com_sf
probe http
rserver microchipdirect_01
inservice
rserver microchipdirect_02
inservice
rserver microchipdirect_03
rserver microchipdirect_04
sticky http-cookie http://www.microchipdirect.com_prog http://www.microchipdirect.com_prog
cookie insert browser-expire
timeout 20
replicate sticky
serverfarm http://www.microchipdirect.com/prog_sf backup outofservice.microchip.com_sf
sticky http-cookie http://www.microchipdirect.com_cookie http://www.microchipdirect.com_cookie
timeout 20
replicate sticky
serverfarm http://www.microchipdirect.com_sf backup outofservice.microchip.com_sf
class-map type http loadbalance match-any http://www.microchipdirect.com/prog
2 match http url /programming.*
3 match http url programming.*
class-map match-any http://www.microchipdirect.com_443_vs
2 match virtual-address 10.10.215.121 tcp eq https
class-map match-any http://www.microchipdirect.com_80_vs
2 match virtual-address 10.10.215.121 tcp eq www
policy-map multi-match VIPS
class http://www.microchipdirect.com_80_vs
loadbalance vip inservice
loadbalance policy http://www.microchipdirect.com_80_l7slb
loadbalance vip icmp-reply
appl-parameter http advanced-options HTTP-PARAM
class http://www.microchipdirect.com_443_vs
loadbalance policy http://www.microchipdirect.com_443_l7slb
ssl-proxy server http://www.microchipdirect.comSSL
04-19-2008 02:37 AM
since you said the config does work in the lab, it means the config is correct for regular traffic.
You need to catch your problem with a backend AND frontend sniffer trace and see what is different with the traffic when it fails.
Gilles.
04-19-2008 07:18 AM
I gathered a sniff trace yesterday and sent it off to Cisco. I know i said this already but i actually see connections which are suppose to be destined for the class default go to the programming site. It seems to be load related as if some of the sticky sessions get confused or something. I also removed one of the servers from each serverfarm and still the same issue.
