static nats with ICMP (extendable)
adamtroxel
Hi all
I have an issue I have never had to deal with.
I did the following to run our packets through an ssl accelerator box.
we had the following set up for our system:
ip nat inside source static 10.1.1.1 5.5.5.5
this allowed our services to be accessed easily. (8080, 443, and ICMP)
However - we needed to change it a bit to set up different ports for ssl acceleration so I needed to move to this:
no ip nat inside source static 10.1.1.1 5.5.5.5
ip nat inside source static tcp 10.1.1.1 443 5.5.5.5 443 extendable
ip nat inside source static tcp 10.1.1.1 8080 5.5.5.5 8080 extendable
Question: how do you get ICMP to work?
thanks!
tstanik
Level 5
Level 5
In PIX, ICMP is permitted by default, but PIX ping responses from its own interfaces can be disabled with the icmp command
icmp permit|deny [host] src_addr [src_mask] [type] int_name
Refer the below URL for the Handling ICMP Pings :
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml#topic2
