Routing between 2 VPN Tunnels
Apr 18th, 2008
I need some documentation/examples of how to setup the following routing.
I have a PIX501 and I want to setup 2 vpn tunnels. Both tunnels will take different paths (frame relay network & verizon wireless data network) to get to the same VPN3000 Concentrator.
The traffic on the inside interface of the 501 needs to be able to take either tunnel to get to the remote destination (a network attached to the VPN3000). Not neccasarily load-balanced but a backup type scenario. Is this something I can use static routes for or would OSPF be better? How do you setup the VPN3000? Is there a better option?
mchin345 Thu, 04/24/2008 - 10:41
  • Silver, 250 points or more
Use the following documents for Routing between 2 VPN Tunnels for PIX 501 and VPN 3000
Cisco PIX 500 Series Security Appliances Configure
http://cisco.com/en/US/products/hw/vpndevc/ps2030/tsd_products_support_configure.html
Cisco VPN 3000 Series Concentrators Configure
http://cisco.com/en/US/products/hw/vpndevc/ps2284/tsd_products_support_configure.html
