Upgrade Firmware 7920
Apr 18th, 2008
Hi Guys,
I have a Wirelles Phone 7920 and I need
to do upgrade of firmware. My doubt is: For to do upgrade I need the configuration utility and USB cable or there is another way of the make upgrade?
Thank You,
Wilson Santana
Overall Rating: 4.8 (3 ratings)
Rob Huffman Fri, 04/18/2008 - 10:07
Hi Wilson,
Hope all is well!
Firmware can be upgraded via TFTP from Cisco CallManager or via USB through the Cisco 7920 Configuration Utility.
Use this procedure to load the latest version firmware image for the Cisco Wireless IP Phone 7920 on Cisco CallManager 3.3(3) SR1 and later. You must install the firmware image on all Cisco CallManager servers that run TFTP service.
Note If you are using Cisco CallManager Release 3.3(2) and earlier, you must also use the phone load image helper file OS7920.txt. The 7920 device type is not supported in earlier releases of Cisco CallManager.
Procedure
Step 1 Download the firmware installation file cmterm-7920-sccp.x-x-x.exe from Cisco.com at the following URL:
http://www.cisco.com/pcgi-bin/tablebuild.pl/ip-7900ser-crypto
Step 2 Double-click the .exe file to install the necessary firmware files in Cisco CallManager.
The version firmware image file and load ID file for the Cisco Wireless IP Phone 7920 are copied into the Cisco CallManager TFTPPath directory.
Step 3 Log in to the Cisco CallManager Administration application.
Step 4 From the menu bar, choose System > Device Defaults.
The Device Defaults Configuration window appears.
Step 5 Scroll down on the page to Cisco 7920 in the Device Type column. In the Load Information window, verify that the firmware image file name is the updated version.
If the updated firmware image version is not in this field, update this entry.
Note Do not change any of the parameters of the firmware image file.
After this has been completed, the next time the 7920 contacts CCM the firmware will be upgraded.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7920/3_3/english/administration/guide/7920frm.html
Hope this helps!
Rob
wilsonsant Tue, 04/22/2008 - 04:32
Hi Rob,
Thank You. I will go test in LAB and return with results.
Rob Huffman Mon, 05/05/2008 - 04:53
Hi Wilson,
Good stuff my friend! Glad to hear this worked.
Take care,
Rob
PS: Don't forget to remember to rate helpful posts ....
sandeep pokhriyal Mon, 05/05/2008 - 05:22
hi Rob,
i want to change the firmware of only two three phone in a cluster is there any way to achieve this.
Rob Huffman Mon, 05/05/2008 - 05:27
Hi Sandeep,
Sure, this is a good way to test out the new Firmware before going system wide. Once you have loaded up the new files on the TFTP Server you change this setting via Device>Phone (find specific phone) then halfway down the phone config page;
Firmware Load Information (leave blank to use default)
Phone Load Name (put the new load name here and reboot the phone so it loads this new firmware)
Hope this helps!
Rob
sandeep pokhriyal Mon, 05/05/2008 - 05:33
i got it..it worked just changed the name of load in phone config and copied the unzipped files to tftp..
