CME 4.3 7937
Tim Smith Thu, 05/08/2008 - 14:05
Ah.. sorry Matt.. didnt see the CME just saw CM! :)
Cheers,
Tim.
davidpfau Mon, 05/12/2008 - 16:47
Thanks for the post Matt!
I didn't see the ephone type suggestion anywhere in the release notes or on any searches for CME and 7937.
adrianotte Wed, 05/14/2008 - 13:43
I entered the ephone-type commands you have above, I created the DN and the ephone, my 7937 shows registered but it doesn't work.
What do you have under telephony-service for the load 7937? I am using the apps37sccp.1-2-1-0.bin
Thanks.
adrianotte Wed, 05/14/2008 - 18:10
Thanks for the reply. I figured out the load command and got it to update the flash, but I am still having problems with the phone. CME shows it registered, I see it looking for a rp-sccp.jar file on the tftp events.
You have a couple more statements under the ephone that I don't have, I'll give those a try.
Thanks again.
