Alternate Pool: I/O Free: 31268 Cause: Not enough free memory
Apr 18th, 2008
Hi there, just purchased some cisco kit - 2 x Cisco 2501 Ethernet Dual Serial Router 16mb Flash / 16mb Dram / IP Plus 12.3 IOS. I've been working through configuring the ports, serial link and passwords etc... On some occassions when running a show running-config i see some memory errors... see below...
Manchester_Router1#show run
Building configuration...
Current configuration : 731 bytes
version 12.3
hostname Manchester_Router1
enable secret xxx
no aaa new-model
ip subnet-zero
interface Ethernet0
ip address
*Mar 1 00:36:35.907: %SYS-2-MALLOCFAIL: Memory allocation of 32768 bytes failed
from 0x3378EE8, alignment 0
Pool: Processor Free: 0 Cause: Not enough free memory
-Process= "Exec", ipl= 0, pid= 3
-Traceback= 337C18E 337D79C 3378EF0 32E6108 32E40F0 32E3E56 335B422 335B458 32E7
DB4 335ECF6 32E4306 32C4708 32C4B76 32FB484 32FB56 E
Manchester_Router1#$LOCFAIL: Memory allocation of 32768 bytes failed
From what i can see the router is running out of memory and i'm not sure why? heres my 'show version' output.. It seems i have 32K on NVRAM, is this normal? if anyone could shed any light on this that would be great. Thanks! Garry
Manchester_Router1>show version
IOS (tm) 2500 Software (C2500-IS-L), Version 12.3(17a), RELEASE SOFTWARE (fc2)
Technical Support:
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 13-Dec-05 00:51 by evmiller
Image text-base: 0x0307DC2C, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c)XB1, PLATFORM SPECIFIC RELEASE SOFTWARE
BOOTLDR: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c)XB1, PLATFORM SP
Manchester_Router1 uptime is 3 minutes
System returned to ROM by reload
System image file is "flash:c2500-is-l.123-17a.bin"
cisco 2500 (68030) processor (revision M) with 6144K/2048K bytes of memory.
Processor board ID 09235735, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Token Ring/IEEE 802.5 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Overall Rating: 4 (2 ratings)
grichardson661 Fri, 04/18/2008 - 23:37
Just looking at my post again. According to the output my current config is 731 bytes and my NVRAM has 32K so i dont see any problems there. It seems RAM is exceeding it limit (i think) Does anybody have any ideas how I confirm this? Thanks,
grichardson661 Sat, 04/19/2008 - 01:33
Found some useful commands below which i'm going to work with... hopefully, this should put me on the right tracks.
Show Boot
Dir flash
grichardson661 Sun, 04/20/2008 - 22:48
Hi Sushil, thanks for the document! I did have a read through this yesterday, didn't get to far :-(. I've just been using the kit as a lab, the memory issue only occurs from time to time, not very often.
fherlan Tue, 04/22/2008 - 08:15
Don't get me wrong, but if I look at the "show version" I can see:
So your router has only 8 MB RAM, right?
Sushil Kumar Katre Tue, 04/22/2008 - 09:45
I guess Frank is correct. The available RAM is 8 MB while what is required for the image you are running is 16 MB.
Plus, the IOS version which you are running 12.3.17a is a deferred release.
So you have two options either upgrade the RAM [I am not sure need to check more on this part] or to run some other IOS release which needs 8 MB Flash.
-> Sushil
grichardson661 Tue, 04/22/2008 - 13:03
Frank, Sushil, thanks for the posts! I sent my seller some outputs of 'show memory', 'show version' and straight away then identified what you guys just quoted! not enough memory! They are sending me a 16DRAM module. Should be here tomorrow! :-) I'm still learning otherwise i would of expected to see this straight away. Goy my CCENT in 3 weeks. Thanks again!
