user tracking
Answered Question
Apr 18th, 2008
can I able to see on user tracking the duplex and the speed , vtp information. or the state of of the device. any way to configure ?
Correct Answer by Joe Clarke about 8 years 10 months ago
When viewing a UT report, if you select the All Columns layout instead of the default Standard layout, you will get columns for duplex mode, port speed, and the VTP domain associated with that entry. Device state is not shown. The device had to have been up at the time the UT entry was last seen.
You can also create custom layouts showing only the columns you want to see. That can be done under User Tracking > Reports > Custom Layouts.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 04/18/2008 - 11:11
