Alarm in a HD
Answered Question
Apr 18th, 2008
Hi all, I have the next problem:
There is an alarm in a HardDisk of my Unity server MCS7835.
Are there any possiblities for fix that?
Any suggestions is aprecited.
Correct Answer by Tommer Catlin about 9 years 2 months ago
I just had a 7845 with the new 10k 72gb drives fail. Went to a "red solid light". Tried to remove the drive, insert it again thinking it would rebuild, but no luck. Failure. Opened a TAC case, they are having HP ship a new drive.
You can open up the HP RAID Array and see which drive has failed. You will probably need to pull the drive, insert it again and see if it rebuilds. If not, RMA it.
Overall Rating: 4 (1 ratings)
hadbou Thu, 04/24/2008 - 10:46
  • Bronze, 100 points or more
Can you provide more information about the alarms you are recieving from the harddisk which will help us in understanding the issue better and providing a solution.
Correct Answer
Tommer Catlin Thu, 04/24/2008 - 19:25
  • Green, 3000 points or more
