VLANs / SSIDs Connectivity
Apr 18th, 2008
Let me try this again..
I am attempting to set up multiple SSIDs and VLANs on a 1121G autonomous / IOS WAP. One appears to be working fine - the other has no connectivity.
SSID = ssid_100 and VLAN 100 seem to be working fine. We can connect and get the appropriate DHCP address.
SSID = ssid_910 and VLAN 910 are not working. The client and the AP both say the client is associated, but DHCP fails. I have used a packet sniffer to verify that the DHCP request is never making it to the switch port.
I think the VLANs on the wired LAN are working fine, because I can plug into a properly configured switch port and get connectivity no problem.
I have attached a snippet of the WAP config. The switchport tthat the WAP is connected to has this config:
interface FastEthernet0/1
switchport trunk allowed vlan 1,100,910
switchport mode trunk
Any suggestions or pointers will be very much appreciated.
Thanks.
Anonymous (not verified) Mon, 04/21/2008 - 08:10
Sorry about this folks, I am trying post a portion of my WAP config and I am getting Tomcat error messages.
Anonymous (not verified) Mon, 04/21/2008 - 08:12
dot11 ssid ssid_100
vlan 100
authentication open eap eap_methods1
dot11 ssid ssid_910
vlan 910
authentication open
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode wep mandatory
encryption vlan 1 mode wep mandatory
encryption vlan 100 mode wep mandatory
encryption vlan 910 key 2 size 40bit 7 transmit-key
encryption vlan 910 mode wep mandatory
ssid ssid_100
ssid ssid_910
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.100
encapsulation dot1Q 100
no ip route-cache
no cdp enable
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
bridge-group 100 spanning-disabled
interface Dot11Radio0.910
encapsulation dot1Q 910
no ip route-cache
no cdp enable
bridge-group 91
bridge-group 91 subscriber-loop-control
bridge-group 91 block-unknown-source
no bridge-group 91 source-learning
no bridge-group 91 unicast-flooding
bridge-group 91 spanning-disabled
no ip address
no ip route-cache
duplex auto
speed auto
no cdp enable
interface FastEthernet0.1
no ip route-cache
no cdp enable
bridge-group 1
interface FastEthernet0.100
no ip route-cache
no cdp enable
bridge-group 100
interface FastEthernet0.910
no ip route-cache
no cdp enable
bridge-group 91
dot11 ssid ssid_100
vlan 100
dot11 ssid ssid_910
vlan 910
authentication open
no ip address
no ip route-cache
ssid ssid_100
ssid ssid_910
no ip route-cache
no cdp enable
bridge-group 1
no ip route-cache
no cdp enable
bridge-group 100
no ip route-cache
no cdp enable
bridge-group 91
bcolvin Wed, 04/23/2008 - 11:55
Basically your your bridge groups, SSID, and Vlan assignmnts don't agree.
1 your native Vlan 1 is your first vlan with no SSID/radio only Fastethernet defined as bridge group 1
2. Vlan 100 assigned to SSID 100 and brige group 100.
3. Vlan 910 assigned to SSID 910 and bridge group 910
you can use whatever SSID you wan for the VLAN's but the numbers for the VLAN and bridge groups need to be consistant.
I recomend you use the GUI to set up VLAN's as it takes care of all the interrelatioinships.
Here is a linl to a good doc on this configuration for AP's
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801d0815.shtml
Best practice is not to use your native VLAN for wireless traffic
Bill
no ip address
no ip route-cache
duplex auto
speed auto
no cdp enable
no ip route-cache
no cdp enable
bridge-group 1
no ip route-cache
no cdp enable
bridge-group 100
no ip route-cache
no cdp enable
bridge-group 91
Anonymous (not verified) Mon, 04/21/2008 - 08:15
Anonymous (not verified) Mon, 04/21/2008 - 08:23
Anonymous (not verified) Mon, 04/21/2008 - 13:58
Anonymous (not verified) Mon, 04/21/2008 - 13:59
Anonymous (not verified) Tue, 04/22/2008 - 07:04
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
