04-18-2008 02:20 PM - edited 03-15-2019 10:09 AM
Gurus, I have a couple of new 7921 wireless phones. Really stupid question here probably, but I can't figure out how to configure them! They turn on and power up OK, and I can browse through some of the menus OK, but I can't determine how to get them pointed to the right wireless network, enter a network key, etc.
Any advice would be appreciated.
-Michael
Solved! Go to Solution.
04-18-2008 03:28 PM
Hi Michael,
Not a stupid question at all my friend :) You can find the info for configuring the 7921 using a USB Cable and your PC here;
Hope this helps!
Rob
04-19-2008 02:06 PM
I find it is easier to follow this link http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/5_0_1/english/administration/guide/7921pcfg.html#wpxref70415
Cheers.
04-18-2008 03:28 PM
Hi Michael,
Hope this helps!
Rob
04-19-2008 02:06 PM
Cheers.
04-19-2008 07:42 PM
Thanks to you both.
For me, the thing that bugs me the most about researching problems, solutions or issues on Cisco's site is the constant barrage of "The page you have requested is no longer available" or some such. I've been dealing with that a lot while trying to set these phones up.
Thanks for the info,
-Michael
