04-18-2008 05:22 PM - edited 03-03-2019 09:37 PM
Hi all,
Can we have multiple tunnels on a router, all of them having same source IP address or same source interface?
--gaurav
Solved! Go to Solution.
04-18-2008 08:10 PM
G:
I see what you're trying to do and you can do it that way.
Although, that is the old way of doing things.
You're probably better off using a DMVPN solution.
In that case, the hub router will have one multipoint GRE (mGRE) tunnel interface and its IP address will be on the same subnet as the tunnel interfaces for all the spokes.
You will use NHRP to have the spoke routers (NHRP clients) advertise their outside IP interface address and map it to their tunnel interface.
The hub router (NHRP server) will build a database of all the spoke's IP address-to-GRE tunnel-address mappings, which allows spokes to be added on dynamically and with only one mGRE tunnel interface at the hub supporting all the connections.
This is the general approach. You run GRE over IPSec and utilize NHRP for dynamic additions to the DMVPN network.
[EDIT] We can pick this up tomorrow, if you need more info, or a sample config. Right now, I need to crash. [EDIT]
Victor
04-18-2008 06:47 PM
Of course you can. A VPN hub router in a hub-and-spoke topology does just that.
Victor
04-18-2008 06:57 PM
Hey Victor,
You are helpful like always.
Kindly validate the same.....
interface Tunnel0
bandwidth 1544000
ip address 192.168.1.2 255.255.255.252
load-interval 30
keepalive 10 3
tunnel source 172.22.24.182
tunnel destination 172.22.152.74
tunnel bandwidth transmit 1544000
tunnel bandwidth receive 1544000
interface Tunnel1
bandwidth 1544000
ip address 192.168.1.4 255.255.255.252
load-interval 30
keepalive 10 3
tunnel destination 172.26.157.74
and at the remote sites.......
First site::
interface Tunnel0
bandwidth 1544000
ip address 192.168.1.1 255.255.255.252
load-interval 30
keepalive 10 3
tunnel source 172.22.152.74
tunnel destination 172.22.24.182
Second site:
interface Tunnel0
bandwidth 1544000
load-interval 30
keepalive 10 3
tunnel source 172.26.157.74
or if you can give out some example.....
--gaurav
04-18-2008 08:10 PM
G:
Victor
04-18-2008 08:38 PM
very right Victor.
I'll be waiting for the sample configs....
--gaurav
04-19-2008 08:02 AM
G:
Here is a link from Cisco's website that has theory, architecture and example configurations.
I'm sure you'll find it useful.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_white_paper09186a008018983e.shtml#dualhubs
And thanks for the rating.
Victor
