How to edit webvpn login page with 7.2 version in ASA5510?
Apr 18th, 2008
Dear guys,
As a solution for business, I have deployed webvpn with 7.2 version in ASA5510(Version 8.0 cannot be used in this case). Could you share some experiences in customizating login page of webvpn manually(not use ASDM)? for example, if I want to add some system tips or links in login page, how to do?
Appreciate your kindly help and suggestion.
Best Regards,
David Wu
smahbub Thu, 04/24/2008 - 11:31
  • Silver, 250 points or more
Customizing login page of webvpn with 7.2 version of ASA is easy to be done and the following Url contains the dcument for customizing the webvpn login page for ASA version 7.2:
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/webvpn.html#wp1031868
This document contains the step-by-step procedure for customizing the login page.
david.wzj Sat, 04/26/2008 - 18:18
Hi Smahbub,
Thanks!
But customization in the introduction is limited. My thought is to add some url or text into the appropriate place on login page.
