Cisco Unity Express and Outlook 2007 Integration
Apr 18th, 2008
Hi, is there a way of integrating Cisco Unity Express with NME-CUE and Outlook 2007 so the users can download their voicemails as .wav attachments.
I've read the documentation on Unity Express 3.1 and it says that Outlook 2003 is supported but I don't see Outlook 2007 listed, is there some kind of restriction or is it possible to integrate Unity Express 3.1 with Outlook 2007 using IMAP?
Thanks in advance
Markus Schneider Sat, 04/19/2008 - 16:21
  • Cisco Employee,
For CUE3.1, I believe only Outlook 2003 was officially tested. But realistically, I doubt there were so many changes to outlook's IMAP implementation that it wouldn't work.
Alternatively, you could use email notifications in CUE, where the audio files are attached to the message and sent to the user's real email box.
daniel.pimentel Sun, 04/20/2008 - 19:20
for the email notification, would you use the
voicemail notification email attach command?
or if you have a document or link pointing with the right directions for the email notifications.
Thanks in advance
