Traffic thru IPsec tunnel
Apr 18th, 2008
How can I check whether traffic is going through tunnel? Tunnel is up and running. When I ping remote end private IP, no replies. ICMP is allowed on PIX. See attached config.
gbudd12345 Mon, 04/21/2008 - 12:27
show crypto isakmp sa will give you counters for packets that are encrypted and decrypted.
--Gavin Budd
husycisco Tue, 04/22/2008 - 02:17
Hi Joseph,
You can use packet-tracer command for achieving what you want.
ankurs2008 Tue, 04/22/2008 - 12:55
From your local LAN IP towards the remote LAN ip (mentioned in the Crypto acl), give a continous ping and parallely run the command "debug icmp trace" and "debug crypto isakmp sa "
joseph.yuffa Tue, 04/22/2008 - 17:25
What the full syntax of the command? I've tried packet-tracer ? on PIX and it came with nothing.
joseph.yuffa Tue, 04/22/2008 - 17:29
What is the full command syntax? I've tried 'packet-tracer ?' on PIX and it came back with nothing. Thanks.
husycisco Wed, 04/23/2008 - 04:43
packet-tracer input inside tcp aninsidehostIP 3389 remotesitehostIP 3389 detailed
