Policy-Map
Apr 18th, 2008
is it possible to policy route based on protocols? i would like to run policy-map on a Cisco 3550 and it route port 80 (wwww traffic only) out a seperate device and have all other traffic go out its default route.
thanks for any info or links!
mohammedmahmoud Sat, 04/19/2008 - 00:14
In the route-map you can use an ACL that matches TCP port 80, or any other port (Protocol) you require.
And please don't forget to enable extended routing via the "sdm prefer extended-match" command.
[edit] And this is a list of the unsupported route-map commands on the 3550:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_19_ea1/configuration/guide/swuncli.html#wp1014499
BR,
Mohammed Mahmoud.
