Pings thru ASA/PIX 7.x
Answered Question
Apr 19th, 2008
got one more question relating to ICMP - with icmp inspection enabled , when pinging from outside host to an inside host or from inside host to outside host - is it required to explicitly permit the return icmp traffic ?
Correct Answer by JORGE RODRIGUEZ about 8 years 6 months ago
Upsolutely, with icmp inspect even if you have acl permiting icmp it will pass through ICMP inspection engine, applies also in transparent mode or multiple context 7.x., guidelines is to use icmp inspection engine.
Overall Rating: 5 (2 ratings)
JORGE RODRIGUEZ Sat, 04/19/2008 - 03:36
Vikram, please refer to this link to learn how inbound and outbound icmp requests works for both PIX code 6.x and ASA 7.x.
To ping a host inside your net from outside you have to permit echos, this assumes there is a static NAT for the intended inside host to be pinged.
To ping from inside to outside two ways to do it.
Quote from link!
Either build an acl
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any source-quench
access-list 101 permit icmp any any unreachable
access-list 101 permit icmp any any time-exceeded
access-group 101 in interface outside
policy-map global_policy
class inspection_default
inspect icmp
vikram_anumukonda Sat, 04/19/2008 - 04:01
This link specifically refers to pinging a outside host from inside.
As you have mentioned with echoes allowed on the outside interface in the inward direction and icmp inspection turned on . The echo-reply from the inside host - will it pass thru the inspection engine or the acl on the inside interface in the inward direction.
Hope you got my question & will this be any different in transparent firewall's ?
