802.1q Tunnel question
Apr 19th, 2008
On the 3560 switches, when configuring an 802.1q tunnel does it need to be point-to-point? Or can you configure it connect multiple sites together? I've looked through the documentation and haven't been able to find if it is permitted or not. The docs don't say either way.
nambi_gct Sat, 04/19/2008 - 20:25
  • Bronze, 100 points or more
you can connect multiple sites.It all depends upon the outer tag and where that vlan is speaded and how many ports receive the traffic.
Hi, as the other poster said yes you can have multible site connected through a tunnel, most document refer to the GRE tunnel which is a point to point connection, GRE tunnel do not send multicast traffic by default so routing table keep alives are not sent across, however you can configure ip pim sparse-dense mode to send multitraffic across the tunnel, see the document below.
I was tasked with setting up multible tunnels for our network using the tunnel mode gre multipoint see some sample config below.
tunnel 1
interface tunnel0
ip address 2.222.254.111 255.255.255.0
no ip redirects
ip nhrp map 2.222.254.1 10.10.222.22
ip nhrp network-id 10
tunnel source loopback0
interface Vlan222
ip address 2.222.11.1 255.255.255.0
ip policy route-map quarantine
route-map quarantine permit 10
match interface Vlan222
set ip next-hop 2.222.254.1
xxxxxxxxxxxxxxxxxxxxxxxx
tunnel 2
interface tunnel0
ip address 2.222.254.145 255.255.255.0
no ip redirects
interface Vlan222
ip address 2.222.45.1 255.255.255.0
route-map quarantine 10
match interface vlan222
GRE multicast tunnel
http://www.cisco.com/en/US/tech/tk828/technologies_configuration_example09186a00801a5aa2.shtml
