Memory Utilization
Apr 19th, 2008
Hi, We are using pix 501 (Ver 6.3) and in which VPN tunnel is estlabished but the memory utilization is too high and CPU utilization is 1 to 2% only. The screenshot is attached for your reference. Thanks
JORGE RODRIGUEZ Sat, 04/19/2008 - 20:41
Do you have a baseline of what memory utilization used to be? did it become high after you confgured the tunnels, my opinion is this could be normal for a 16 megs of RAM firewall, unless you start seeing pix stoping traffic or crashes then I would start looking into solutions,but! I would definatly recommend to boosting your memory to 32 MB.
Read this link to give you an idea of things to look for, if none applies I would consider placing more memory in your firewall.
