radius client ip address
Answered Question
Apr 19th, 2008
Is there any way to define ip address what cisco device use when connect to MS IAS server. I have configured to MS IAS client and client is cisco 6509 router box and client ip is 6509 ip address(management address) Problem is that cisco uses different ip address (not routers management adress what i have configuréd to MSIAS client ip) when it start to discuss with MS IAS server. Can i tell cisco 6509 router what ip address it uses when start to change packets with MS IAS.
Correct Answer by Jagdeep Gambhir about 8 years 9 months ago
ip radius source-interface
To force RADIUS to use the IP address of a specified interface for all outgoing RADIUS packets, use the ip radius source-interface global configuration command.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios113ed/cs/csprts/csprts2/cs_rad.htm#xtocid231301
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
