CUCM6-BE
Answered Question
Apr 19th, 2008
we are proposed to our customer Cisco Unified Communications Manager Business Edition for 400 users.The system support voice, video, mobility, and messaging on a single server. Please suggest me about licensing for Phone, Voice messaging.
What do you mean Seat Licenses ? ( Is it represent to total number device/Phone)
Please give me ur suggestion ASAP
Manoj
Correct Answer by Sushil Kumar Katre about 9 years 3 months ago
Hi All,
Just an upgrade Mobility feature now requires 4 DLUs per user instead of 2 since UCM 6.1.
>> Sushil
Overall Rating: 5 (1 ratings)
Rob Huffman Sun, 04/20/2008 - 03:02
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Manoj,
The Seat License is = to the number of users, so for your proposal you would need to order 350 Seat Licenses (as BE comes with 50). Each Seat License includes a VM Box. Then you need to order DLU's (Device License units for the number/type of IP Phones as well. The different Phone models require varying amounts of DLU's depending on the model;
Here is the DLU breakdown;
Cisco Unified IP Phone 7902G = 1
Cisco Unified IP Phone 7905G = 2
Cisco Unified IP Phone 7911G = 3
Cisco Unified IP Phone 7912G = 3
Cisco Unified Wireless IP Phone 7920 = 4
Cisco Unified IP Conference Station 7936 = 3
Cisco Unified IP Phone 7940G = 4
Cisco Unified IP Phone 7941G = 4
Cisco Unified IP Phone 7941G-GE = 4
Cisco Unified IP Phone 7960G = 4
Cisco Unified IP Phone 7961G = 4
Cisco Unified IP Phone 7961G-GE = 4
Cisco Unified IP Phone 7970G = 5
Cisco Unified IP Phone 7971G = 5
Cisco Unified IP Phone 7985G = 6
Third-party SIP device (basic) = 3 (third-party)
Third-party SIP device (advanced) = 6 (third-party
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item0900aecd805009fc.shtml
Hope this helps!
Rob
manojdubey02 Sun, 04/20/2008 - 03:28
Hi Rob,
Thanks for your support ....Its really useful information to design the solution
Manoj Dubey
manojdubey02 Sun, 04/20/2008 - 03:49
Dear Rob,
Can you tell me cisco unified communication manager is support all cisco IP phone (like CP-7965G, CP-7945G=, CP-7975G ) ???
Becouse these phone is not there in ur sent list and as well in pdf file ..
Manoj Dubey
hbarrera2 Sun, 04/20/2008 - 05:28
manojdubey02,
Yes the 7945 and 7965's are supported, they will take up the same amount of DLU's as the 41/61's. Also keep in mind that the mobility feature takes up 2 DLU's per user.
This really screwed us after selling and deploying CUCMBE 6.0.
Cheers!
manojdubey02 Sun, 04/20/2008 - 06:10
As per your response, CP-7945G and CP-7965 needs DLU 4 unit each and +2 unit for mobility feature. Its means each CP-7945 need total DLU 6 unit....
Please suggest me whether its correct or worng ?
Correct Answer
Sushil Kumar Katre Sun, 04/20/2008 - 20:39
  • Gold, 750 points or more
Hi All,
>> Sushil
hbarrera2 Mon, 04/21/2008 - 14:04
"DLU 4 unit each and +2 unit for mobility feature"...
Your above statement is correct, for 6.0 CUCMBE. Not sure if this would change down to 4 DLU's only if you upgrade to 6.1 CUCMBE. Sounds like it will, I would confirm with cisco.
Cheers
