IDSM2 and IPSEC-2G setup
Apr 20th, 2008
I'd like to have the following setup:
-Cat6500 with IPSEC2G SPA and IDSM2, using crypto connect to IPSEC-2g internal interface
-VPNs from remote sites terminate on VLAN number 500
-Traffic between remote peers gets through 6500 (there is decryption and another encryption)
-Routing to all remote sites in through the VLAN 500 (there are all routing peers connected to it), it means, that packets coming from one VPN are decrypted on IPSEC, and directed to MSFC VLAN 500. Then, are routed again through VLAN 500 and encrypted on IPSEC 2G.
The question is: is it possible to use IDSM2 module to analyze the traffic when is after decryption and before another encryption?
Is it possible in the inline or only promiscous mode?
Krzysztof
bwilmoth Fri, 04/25/2008 - 07:36
  • Silver, 250 points or more
You can use IDSM2 to analyze the traffic you can try with Promiscous mode
