871: dialer interface doesn't get an ip address from isp
Apr 20th, 2008
Hi all,
I'm trying to get the attched config to work. The problem is with the dialer interface (I think). Although I 'm asking an ip-address from the ISP, with ip address negotiated, it is not delivered.
I get the following message with 'debug ip nat': dialer not up for dialer1.
Dialer1 is up, line protocol is up (spoofing)
I get the following message with 'debug dialer': cannot place call, no dialer string !!!
When I let the F4 int dhcp for an address, it gets one. And further, when I substitute Dialer1 with F4 in the lines:
- ip route 0.0.0.0 0.0.0.0 Dialer1 permanent
- ip nat inside source list 1 interface Dialer1 overload
it works. but thats not how I want it.
Any ideas?
Jaap
Netherlands
paolo bevilacqua Sun, 04/20/2008 - 13:42
  • Hall of Fame,
    Founding Member
Hi, dialer interfaces are for ppp, not dhcp. Use int FA4 for external address, or what are you trying to do ?
jlaay-diode Wed, 04/23/2008 - 11:39
What I want to do is to get an IPsec/VPN tunnel over Internet between two sites.
I tried the example config mentioned in the following example config.
http://articles.techrepublic.com.com/5100-1035_11-6130365.html
http://i.i.com.com/cnwk.1d/i/tr/downloads/home/cli_config_worksheet.xls
This config uses a Dialer as it would be suggested by Cisco instead of using a physical interface.
That why actually.
I changed the worksheet and use solely fastethernet 4 interface and then it works. What I 'm then missing is the possibilty to use PAP/CHAP check (or not?).
Jaap
paolo bevilacqua Fri, 04/25/2008 - 08:29
  • Hall of Fame,
    Founding Member
Hi, you do not have PPP hence dialer does not apply, neither do pap/chap.
Just configure ipsec/vpn one the FA4 interface.
If you want also to control QoS, etc, get an 877 and interface directly to the ADSL.
