Failover IOS
wasiimcisco
I have UR bundle PIX firewall, I am having strange problem with FO firewall, after upgrading the IOS image when i reboot it it always comes with the old IOS image. So many times I upgrade the IOS, but after reboot it again comes back with old image. The flash shows only one image not two image. I updgrade the IOS in monitor mode, can anybody help me out why it is so. and how to slove this problem, bcz after reboot my primary firwall gave me error that IOS is not match with the mate etc
knudsen-s
Fist is you look in the flash what file do you have ? and what version are we talking about (from / to)
You can have a boot ldr that is poiting to the old PIXOS Image.
/Soren
I have only one file in flash which is image.
I applied this command and got the following error,
fw(config)# boot system flash:/image
ERROR: Unable to set this url, it has already been set
Remove the first instance before adding this one
after reboot it is again giving me same error,
PDC-Srv-525-1# d
************WARNING****WARNING****WARNING********************************
Mate version 7.2(3) is not identical with ours 7.2(3)8
************WARNING****WARNING****WARNING*********************************
ebuBeginning configuration replication: Sending to mate.
you need to perform "copy tftp flash:" again.
When you do it from "rommon" mode, it only
copies from tftp to the RAM, NOT Flash. Do it
again with "copy tftp flash:" and you will see
the image in flash.
