BRI problem
Apr 20th, 2008
I have 2 BRI channels(4*64Kbps) to a Remote site. Also from the Remote site the same.
1. How can i use them so i can have 256 Kbps to the remote site?
2. Is it possible to use only one ip address per site?
3. If i can not use 1 ip address is there any special configuration so all the bandwidth(256Kbps) can be available all the time, just like i have Frame Relay CIR 256Kbps?
Thanks a lot
Moses
paolo bevilacqua Sun, 04/20/2008 - 12:57
  • Hall of Fame,
    Founding Member
1 yes, associate multiple interfaces to same dialer interface.
2 yes, dialer ip address. pool members use no address
3 -
