Multi Level Administration MLA for Client Matter Codes
Apr 20th, 2008
  • Silver, 250 points or more
I have CM 6.1 and trying to figure out the way to enable a user to admin the client matter codes and nothing more or at least nothing much more that that. I dont see a role that allows just client matter codes. Anyone know the best approach? I figure I would have to allow something that would include CMC but I just have not messed with MLA that much before.
shane.orr Sun, 04/20/2008 - 08:34
Never Mind I found it, just was looking for something called client matter codes.
Did not notice the thing staring back at me that said CMC
mkoncurat Fri, 04/25/2008 - 11:42
Where did you find this? I'm looking for the same level of security for a user.
shane.orr Sun, 04/27/2008 - 07:49
Well I am not sure I ever really found it anywere. But I used Groups with Roles.
Groups/Roles are detailed in the 6.1 administration guide.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
But basically I created a Group with Roles of Read for just about everything and write access to just the "CMC" for Client Matter Codes...or in your case whatever you want this user to be able to modify.
Then I applied this Group to the End User.
There might be a Group already in there called something like Standard CCM Admin Read Only that you could use and then just create an additional one that just has write access and apply both to the user.
Hope that helps
