04-20-2008 12:03 PM - edited 03-05-2019 10:29 PM
i am trying to use PoE feature on cisco catalyst 3750 with IP Base image but it seems not supported, is there any image recommended for that ?
Mustapha Bensalah
04-20-2008 02:55 PM
It all depends on the 3750 model that you have. Not all 3750 models support POE. Here is a good link for you to verify your switch model and see if your model supports POE.
http://www.cisco.com/en/US/products/hw/switches/ps5023/index.html
04-25-2008 04:52 AM
many thanx !
04-20-2008 07:46 PM
PoE is not a software feature. What's the model of your switch as listed in your sh ver?
04-21-2008 06:15 AM
I think it says POE on the front of the box if it is POE , at least the 3560's do .
