trunking and vlans
Apr 20th, 2008
hi every body
i have few questions about trunking between
two switches.
Should the ports being used on both switches be in same vlan for trunking for example: sw1 has follings config
f0/1-f0-0/5 in vlan1
f0/6- f0/10 in vlan2
sw2 has following config:
f0/1-f0/5 in vlan1
f0/6-f0/10 in vlan2
Can i use port f0/4 from vlan1 on sw1 as a trunk to port f0/6 from vlan2 on sw2 ?
or is it necassary ports being used for trunking be in same vlan on both switches?
thanks alot have a nice day!
ilnaiduccna Sun, 04/20/2008 - 20:23
As everybody using for trunk in between switches the both ports are same and vlan also.
in switch 1
fa0/1 in vlan 2
in switch 2
fa0/2 in vlan 2
Naidu.
Jon Marshall Sun, 04/20/2008 - 22:54
When you configure a port as a trunk it is not allocated to any one specific vlan so it doesn't matter what vlans the ports are in as access ports.
Jon
