Port security switch on CE500
Answered Question
Apr 20th, 2008
Dear All,
i would like to ask you that: how can i setup port security on Switch Cisco CE 500? ( i mean that per port per host)
Best Regards,
Rechard
Correct Answer by huzefamerji about 8 years 11 months ago
dear richard,
the command is .......
go to the interface
switch-port port-security mac-address sticky (for automatically taking the mac-address of the connected device)
and if u want to do static entries.
switch-port port-security mac-addresss .........
Overall Rating: 5 (1 ratings)
rechard_david Sun, 04/20/2008 - 22:24
Dear Sir,
Thank you for your link.
i read document that you send to me but i still cannot find the option set port security.
as like Cisco switch 2950 it has command for do switchport port-security mac-address XXXXXXXx by the way i cannot find this option on the webbase. Could you tell me how can i do it ?
Best Regards,
Rechard
rechard_david Mon, 04/21/2008 - 17:20
Dear all,
Everyone could you help me!!!!!!
I had problem on Switch CE-500. i would like to set mac-address on port ( i mean F0/1 connect to PC1 and when PC 2 or other PC want connect to F0/1 it doesn't work(port-security). but i don't see the option, the document tell that it can support smartport and port-security,So i not clear smart port and port-security How can CE-500 can do on port?
i Hope everyone can help me on this!!!
Best Regards,
Rechard
Correct Answer
huzefamerji Wed, 04/23/2008 - 00:22
dear richard,
go to the interface
