Hi There
If I understand your question correctly you are asking which of the two expansion modules you listed support routing?
If I am correct in my understanding, then as far as I know neither of these two modules support routing. Both of these modules are layer 2 modules and provide layer 2 functionality to a router.
Best Regards,
Michael
Richard Burts Mon, 04/21/2008 - 04:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Amoeba
I believe that Michael is correct in identifying both modules as layer 2 switches. And as such the layer 2 switch can not provide routing.
However the module is generally inserted into a router which does provide routing. So if you configure 1 or more VLANs, assign ports to the VLANs, and configure VLAN interfaces with IP addresses, then the router in which the module is inserted should provide routing for the devices connected to the layer 2 switch module.
Rick
Richard Burts Tue, 04/22/2008 - 04:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Amoeba
It seems to me that the link you provide gives confirmation to the answers that we already gave you. On both modules that you ask about in the table it clearly says that layer 3 switching (routing) is done on the router and not in the switch module. The modules that it indicates can do layer 3 switching in the module are: EtherSwitch Service Modules (NME-16ES-1G, NME-16ES-1G-P, NME-X-23ES-1G, NME-X-23ES-1G-P, NME-XD-48ES-2S-P, and NME-XD-24ES-1S-P and these are not the modules that you asked about.
Rick
