04-20-2008 11:25 PM - edited 07-03-2021 03:45 PM
hi,
am trying to upload a customised web authentication page on to my wlc 4402.am using tftpd32 ver 3.23.
the operation is failing,an i get the following error message on the tftp server.the file webathentiaction.tar is in the root directory of the tftp server.
Connection received from 10.1.16.10 on port 7712 [21/04 09:18:37.055]
Read request for file <./webauthentication.tar>. Mode octet [21/04 09:18:37.055]
File <.\webauthentication.tar> : error 2 in system call CreateFile The system cannot find the file specified. [21/04 09:18:37.071]
Rcvd DHCP inform Msg for IP 10.1.18.244, Mac 00:04:23:1B:A1:92 [21/04 09:18:39.352]
04-22-2008 04:13 AM
Verify the setting on the tftp server and make sure of the root directory. I use 3cdaemon for tftp which works great. Also... what error do you see when you try to upload the tar file to the wlc.
04-22-2008 04:44 AM
it just says file transfer failed am using tftpd32
04-22-2008 05:01 AM
hey am thinking that my file might be wrong,hos is the file suupoesd to be like because mine is is a couple of file put in a folder named x.tar(example)
04-22-2008 05:05 AM
You should have a login.html and a logo file if there is one. Then tar up the files and name it login.tar.
Try to download 3cdaemon for the tftp.
http://www.petenetlive.com/Tech/Apps/Misc/tftp.html
