ASA5540: Single Interface for both http and IPSec traffic
Apr 21st, 2008
I'm configuring ASA5540, I want to use only one interface (outside) to connect to the internet i.e. to pass http traffic and ipsec tunnels. I can connect to the internet ok but the problem is with IPSec, i cannot establish Remote Access connection to the same interface. No logs are logged that means vpn traffic is not reaching my interface, what could be the problem?
JORGE RODRIGUEZ Mon, 04/21/2008 - 20:08
It could be anything, one would have to see your ASA RA configuration, I would suggest to go over this link which provides basic ASA VPN server configuration and compare most likely your config is missing something.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008060f25c.shtml
If you still have problems can you post sanatized config.
Rgds
Jorge
