vms 2.3 performance issues
Answered Question
Apr 21st, 2008
I have just installed VMS 2.3 on Solaris 8. The server is with 2GB RAM and 4GB SWAP.
I have serious performance issues with VMS, for example, opening the "Management Center for VPN Routers" screen takes 1-2 minutes.
I tried to improve the performance by removing the "IPS Management Center", but still VMS is really slow.
Would you please give me some advice about the problem?
Thanks in advance,
Mladen
Correct Answer by jbayuka about 9 years 2 months ago
Refer to Troubleshooting Installation section of Installing the VPN/Security Management Solution (VMS) 2.3 on Solaris for more information
http://www.cisco.com/en/US/docs/security/security_management/vms/2.3/install/guide/solaris/sqsapa.html#wp1009106
Overall Rating: 4 (1 ratings)
mladentsvetkov Sat, 04/26/2008 - 09:05
Hi,the problem was duplex/speed mismatch between the server and the switch.
Mladen
